wont some input from you guys plz
if a sx is lagish til about 3000rpm and the just goes like hell afterwards wot can it be?
i have tried a few things but cant seem to get it right
can i just have ur views pls guys
lifes a bitch then u marry one
- Daniel
- Real Name: Daniël
Why would that make it lag?? I've got a 8 port head and it worked fine...while the engine stil ran that israt wrote:8 port head
and you havent even checked the timing yet...and the plugs are looking worse for wear.if a sx is lagish til about 3000rpm and the just goes like hell afterwards wot can it be?
theres no miricle answers here my friend
Hennie Marais
- Daniel
- Real Name: Daniël
Sokar says (well he would) stop being a lazy git and eliminate the 1st options...did you test it after you stole my coil? nope...you havent (because you cant) checked the timing, mani gaskets?? what about checking the ECU for fault codes?Xavier wrote:sokar wot do u think , checkd coils,and boost pipes all good
wot else can it b
BASICS BASICS BASICS!!! once you eliminated those then post on the forum for advice on how to check the efficiency of the hamsters running on their wheels in the exhaust or what have you
- ChemCool
Goodness Daniel... I did not know you can be so to the point??Daniel wrote:Sokar says (well he would) stop being a lazy git and eliminate the 1st options...did you test it after you stole my coil? nope...you havent (because you cant) checked the timing, mani gaskets?? what about checking the ECU for fault codes?Xavier wrote:sokar wot do u think , checkd coils,and boost pipes all good
wot else can it b
But you know what? You are right.
Chem
