wont some input from you guys plz
Xavier
Post by Xavier »
if a sx is lagish til about 3000rpm and the just goes like hell afterwards wot can it be?
i have tried a few things but cant seem to get it right
can i just have ur views pls guys
lifes a bitch then u marry one
8 port head
Blowing mani gaskets
Small boost leak
you know the drill, stop being lazy
rat wrote:8 port head
Why would that make it lag?? I've got a 8 port head and it worked fine...while the engine stil ran that is
and you havent even checked the timing yet...and the plugs are looking worse for wear.
theres no miricle answers here my friend
Xavier
Post by Xavier »
i just want different views 2 try all of them 2 nite
HancoB
Post by HancoB »
Turbo lag????
Haha :lol: :lol: :lol:
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
I'd say double check the 8 port diaphram, also make sure timing is spot on, I've had that... timing was out by one tooth
Hairdresser MX5
Hennie Marais
Post by Hennie Marais »
make sure the wastegate closes properly,
Xavier
Post by Xavier »
cant check timing some idiot removed the bottom cover
Xavier
Post by Xavier »
sokar wot do u think , checkd coils,and boost pipes all good
wot else can it b
Xavier wrote:sokar wot do u think , checkd coils,and boost pipes all good
wot else can it b
Sokar says (well he would) stop being a lazy git and eliminate the 1st options...did you test it after you stole my coil? nope...you havent (because you cant) checked the timing, mani gaskets?? what about checking the ECU for fault codes?
BASICS BASICS BASICS!!! once you eliminated those then post on the forum for advice on how to check the efficiency of the hamsters running on their wheels in the exhaust or what have you
ChemCool
Post by ChemCool »
wot else can it b
Goodness Daniel... I did not know you can be so to the point?? :shock:
But you know what? You are right. :D :D :D :D let him feel!! :lol: :lol: :lol:
:lol:
Chem :lol: :lol: :lol: :lol: :lol:
COOLER, FASTER, LIGHTER
Sokar
1.0 Bar Boost
Post by Sokar »
Hehe.
Well the guys have pretty much covered, timing will make a car feel laggy, since you dont have a cover I'd definately check that first, beg borrow and steal, make it happen.
I dont think the butterflies will make a huge diff if they stay open all the time.
Captain Slow to the rescue!
MyPRodOL
Post by MyPRodOL »
it won't perform under 3000, its lag.
normal.
