can anyone tell me which is the oil inlet and which is the oil outlet on my turbo
turbo inlet and outlet
whats up guys!!
- Attachments
- 2015-08-05 21.47.38.jpg (636.24 KiB) Viewed 17281 times
Re: turbo inlet and outlet
Top pic in, bottom pic out
Schweeet gents thanks
My turbo is also water cooled so where would the coolant lines from the turbo go into the engine(rb25det neo with greddy intake). When I bought the motor it pretty much came as a naked engine. Stripped of its pipes and fittings
I didn't even think of that haha
I'm struggling to find the answer I am looking for on the good'ol interweb. In which direction does the engine coolant flow. I have a greddy intake.
a fool by his own.
a fool by his own.
Thanks for the link but doesn't mention flow direction.
Please can someone who knows advise me
2 is oil feed, 3 is water return. Not sure what 1 is, my SR doesn't have that...
Is 3 not turbo oil return? turbo coolant lines are 8mm hoses max usually
ok i figured out that 1 is turbo oil drain back, 2 is turbo oil feed and 3 is oil drain from head(rear) .Thanks guys
now to figure out where the turbo coolant feed and return go from the turbo...?
Just find the 2 coolant connections that are left unused, coolant feed and return can be connected either way onto the turbo aslong as it's a closed loop. And remember turbo central core must be positioned/rotated so that oil feed is ontop and oil return at the bottom for gravity to return the oil correctly
