ca18det rev limitor
ca18det rev limitor
does anyone have a clue why my motors rev limitor kicks in way to early? it limits it at around 5500 6000rpm
Re: ca18det rev limitor
Yes
With the amount of info available I'm going to guess boost cut.
sorry
its a ca18det standard ecu motor just been re done timing has not been done yet just adjusted by the sound. what is boost cut
1) Set your timing properly before you nuke your rebuilt motor.
2) Do you have the stock T25? running stock boost? I'm guessing not.
Boost cut: When your MAF maxes out the ECU cuts fuel to prevent the over-boost as your fuel system cannot support that much air into the motor.
PS: You say it's the rev limiter, but it could also be that your cam timing is out one tooth and the motor simply cannot increase rpm - this is a common mistake when working on CA's.
kwl thanks alot for the help ![200SX_200SX [smilie=200sx_200sx.gif]](./images/smilies/200SX_200SX.gif)
NIZAN-R
- Real Name: Renier
also check if feul lines to rail is not wrong way around
Kwl will do but i got a feeling im a tooth out on my timing. When i set the timing with a timing light it must match up with the second ridge right?
NIZAN-R
- Real Name: Renier
yes second mark
I checked and mine is way out and adjusting the cas still doesn't bring it to the second mark it must be a tooth out
