Help!!
Grant222
Engine: 2JZ
Real Name: Grant Jones
Help!!
Post by Grant222 »
So, my s13(CA18DET) is having some issues, when i start it(cold start) i need to keep my foot on the gas or else it dies, when its upto temp it seems better but will still die once or twice and when it does not die it idles at around 850-950rpm, and if i put my lights on it just dies instantly if im not keeping the revs up??? What could it be??
White Fang
Real Name: Qubitt (Qbit)
Re: Help!!
Post by White Fang »
There is a problem !
Did you set the idlinhg up a bit ? That could help ,
Or its time for a good dyno again ,
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
Re: Help!!
Your cold start map and temp compensation map is not set up right.
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
but how could it lose it after 7months? that time when I dynod it al workd 100%, choke workd etc
Re: Help!!
You will have to start fault finding, check whether all the sensors is working, check if your map is the same as you remember...funny shit happens buddy...obveously there might be something else wrong...but that is the obveous...
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
I cant check my map, dont have the right program to see, and cant download it anywhere
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Oh and my engine temp sensor etc is working
Re: Help!!
What management you running, then I don't know buddy...if all the hardware is in good working order, then I don't know?
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Mr Turbo, then it can only be the map, iv emailed RBTS to see if they have my old map still to compare for me
Re: Help!!
I have Mr. turbo 1.68 and 1.69....
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
I do to, but when i plug into my laptop, it either doesnt pick up or it picks up then freezes, but it may be that im using RD232 to USB and not the non USB cable?
Re: Help!!
Thats speed setting on you com port...and or the driver for your RD232 to usb....
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
How do i set that stuff?
Re: Help!!
Shit man, hard to explain, try and get your laptop and car to me at some stage, also bring the driver along....this is if you want to....
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Ok i just got a firewire driver for my windows, will install it to laptop and see if it goes better, if it does ill save the map to the pc and see if i can open it up to see whats what
