Help!!
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
- Real Name: Grant Jones
Help!!
So, my s13(CA18DET) is having some issues, when i start it(cold start) i need to keep my foot on the gas or else it dies, when its upto temp it seems better but will still die once or twice and when it does not die it idles at around 850-950rpm, and if i put my lights on it just dies instantly if im not keeping the revs up??? What could it be??
- White Fang
- Real Name: Qubitt (Qbit)
Re: Help!!
There is a problem !
Did you set the idlinhg up a bit ? That could help ,
Or its time for a good dyno again ,
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
Re: Help!!
Your cold start map and temp compensation map is not set up right.
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
Re: Help!!
but how could it lose it after 7months? that time when I dynod it al workd 100%, choke workd etc
Re: Help!!
You will have to start fault finding, check whether all the sensors is working, check if your map is the same as you remember...funny shit happens buddy...obveously there might be something else wrong...but that is the obveous...
Re: Help!!
What management you running, then I don't know buddy...if all the hardware is in good working order, then I don't know?
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
Re: Help!!
Mr Turbo, then it can only be the map, iv emailed RBTS to see if they have my old map still to compare for me
Re: Help!!
I have Mr. turbo 1.68 and 1.69....
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
Re: Help!!
I do to, but when i plug into my laptop, it either doesnt pick up or it picks up then freezes, but it may be that im using RD232 to USB and not the non USB cable?
Re: Help!!
Thats speed setting on you com port...and or the driver for your RD232 to usb....
Re: Help!!
Shit man, hard to explain, try and get your laptop and car to me at some stage, also bring the driver along....this is if you want to....
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
Re: Help!!
Ok i just got a firewire driver for my windows, will install it to laptop and see if it goes better, if it does ill save the map to the pc and see if i can open it up to see whats what
