Hey guys i drive a s13 with a slant top sr20det with management. I would like to removed my middle silencer box but is it safe iv been told i could burn valve's, oh and i have 63mm exhaust.
Thanks
Exhaust
NIZAN-R
- Real Name: Renier
Re: Exhaust
best exhaust is no exhaust!!!!!
the turbo gives the needed back presure so no burnt valves .
ps fit 76mm with one box you will be smiling
- mario_200sx
Re: Exhaust
Agreed, fit a 76mm. When I had the car I had that pipe on with only the backbox.......it f*#kin LOUD! Car alarms go off when you drive past it!
It wont do any damage to the exhaust, but you wont benefit in power.
Kadi
- Real Name: Kadi
Re: Exhaust
Hi guys, my CA is stock std and I want to upgrade my exhaust system to 76mm but getting alot of conflicting views from exhaust fitters, such as the T25 turbo lifespan will be reduced due to the diameter of the pipe "76" ,,, others claim 63mm is the best option as the turbo exhaust housing maybe example 45/50 mm so 76 is way too big. I would appreciate some input from you guys ... If any of you have fitted a bigger exhaust system to your std CA, what was the advantages and disadvantages ... Thx guys in advance for any and all your advisee.
- k.y.l.e.
- Real Name: kyle
Re: Exhaust
Thanks guys so i should go 76mm and would that give me a slite performance upgrade or alot.
- aep886
- Real Name: Davey
Re: Exhaust
advantage = horsepower increase
disvantage = fuel consumption increase
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
NIZAN-R
- Real Name: Renier
Re: Exhaust
my ca runs std turbo after the 76 exhaust it was verry nice power gain 76 is the best way to go .
if you get smaler you will kick your self as you will be paying twice
- mario_200sx
Re: Exhaust
Slight performance gain especially when you remap the ecu, also better spooling....k.y.l.e. wrote:Thanks guys so i should go 76mm and would that give me a slite performance upgrade or alot.
- k.y.l.e.
- Real Name: kyle
Re: Exhaust
Thanks guys you have been a great help.
