where dose this go
Shikar
where dose this go
Post by Shikar »
dose anyone know what the water pipe under the exhaust manifold is for
Re: where dose this go
Water cooling for the turbo
Shikar
Post by Shikar »
it is a top mount turbo of a sr20 there are 2 oil pipes and 1 that goes to the block for water under the exhaust manifold . do i have this right so far ? THEN theres the pipe that goes to the back of intake manifold what does that do???? By the way i have a ca motor
Yeah, the water pipe coming from the turbo goes into the block, the water pipe going to the turbo goes into a chamber on the intake manifold and then to the turbo. After engine shutdown the steam created by the turbo rises into this chamber and cools back into water.
Shikar
Post by Shikar »
Thanx that helps alot
