urgent advice needed
I got a ca18det with a T28 turbo.I still got pretty much everything standard bt she still isn't running ryt.the idleing is horrible off.wat is the next step 2 making her faster an better.gotec? Dumpvalve? Wats the next steps?
- aep886
- Real Name: Davey
Re: urgent advice needed
do stage 1 first~! filter and exhuast!sean wrote:I got a ca18det with a T28 turbo.I still got pretty much everything standard bt she still isn't running ryt.the idleing is horrible off.wat is the next step 2 making her faster an better.gotec? Dumpvalve? Wats the next steps?
stage 2 is intercooler and ECU
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- P3g4sus
- Club Drifter
- Car: Supra
- Engine: 2JZ
- Real Name: B.G. Smit
AgreedBigKriss wrote:Sean, get the std. stuff working 100 % first. Idling problems could be air flow meter leaks, messed injectors, fuel pump pressure, ignition system, a myriad of possible causes..
Once its running as it should stock, then start "upgrading" things.
My 2c worth.
Traction is over rated.
- POWDER
- Real Name: Mike
Best advice that, otherwise u sit like me for 2 years doing all the nice things, but never solving the problem, he he he, it is fun though, lolP3g4sus wrote:AgreedBigKriss wrote:Sean, get the std. stuff working 100 % first. Idling problems could be air flow meter leaks, messed injectors, fuel pump pressure, ignition system, a myriad of possible causes..
My 2c worth.
