Water to the turbo really needed?
H8rlequinb
Post by H8rlequinb »
Greetings Guys.
Ok just a quick q. Mechy told me that he is going to blank off the water pipe going to the turbo.... Reason being that the turbo heats up the engine 's water unnecessarily. I know the turbo will take longer to cool down and need a longer time to idle etc..... I am just reasoning that why would they do all the effort in the first place?
You aren't racing until your breaking shit... My SX is stuffed!!! Point proven ;)
hentiebez
Re: Water to the turbo really needed?
Post by hentiebez »
H8rlequinb wrote:Greetings Guys.
think you just answered your own question
H8rlequinb
Yea I'm clever like that sometimes... ;) But really though what will happen if there is no water to it?
I the turbo is designed to take water ,it needs water.
H8rlequinb
Charlvdw wrote:I the turbo is designed to take water ,it needs water.
Great thanks... All I needed to know... Will tell the mechy he is an idiot ;)
Thanks.
300sx
0.8 Bar Boost
Post by 300sx »
water through the turbo bearing housing helps the turbo live longer..
so choose,
less heatload on the cooling system, or shorter turbo life.. :wink:
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
aep886
Real Name: Davey
Post by aep886 »
Trust turbine dont even have water cooling... they are just as good!!!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
aep886 wrote:Trust turbine dont even have water cooling... they are just as good!!!
True but they are designed that way.
aep886
Real Name: Davey
Post by aep886 »
but Trust turbo performs well without water cooling... and plain bearing...
take the Trust T88 34D VS HKS T51R SPL the same setup, but T88 will chunk out more hp
current vehicles...
1979 Corolla SR5
1996 S14 200sx
hentiebez
Post by hentiebez »
the water cooling is there to keep the oil around the shaft cool not the turbo
RB25SX
Post by RB25SX »
Quote from Garrett web page:
"Water cooling is a key design feature for improved durability and we recommend that if your turbo has an allowance for watercooling, hook up the water lines. Water cooling eliminates the destructive occurrence of oil cooking by utilizing the Thermal Siphon Effect to reduce the Peak Heat Soak Back Temperature on the turbine side piston after shut-down. In order to get the greatest benefit from your watercooling system, avoid undulations in the water lines to maximize the Thermal Siphon Effect."
R32 GTR
Gizmo
Post by Gizmo »
also, the water lines where used on alot of OEM cars as the winter temps in other countries are generally alot colder than ours, running the water system thru the turbo allows the car's water to reach operating temperature quicker from cold start!
"Growing old is mandatory, growing up is optional"
ex: Audi A3 1.8T 204 kw atw (sold)
ex: VW Mk1 2.0 8v (sold)
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
Well here is the equation:
Water to turbo = cooler turbo = cooler compressor = cooler charge = cooler oil
turbo heating water = quicker climb to operating temp
turbo heating water = more strain on cooling system
stock turbo + stock boost level = stock temp
bigger turbo or/and more boost = more strain on cooling system
bla bla bla bla etc etc fit an ally radiator if the temps are too high...
Nissan spent millions on R&D on the design so don't mess with it. Besides if there is water lines currently and you are not fitting a turbo that does not have ports WHY would you take it off... Just dont do other stupid stuff like take off the viscous fan... and if you do add lots of electric ones.
my 2c... :wink:
