Water to the turbo really needed?
- 0.2 Bar Boost
Greetings Guys.
Ok just a quick q. Mechy told me that he is going to blank off the water pipe going to the turbo.... Reason being that the turbo heats up the engine 's water unnecessarily. I know the turbo will take longer to cool down and need a longer time to idle etc..... I am just reasoning that why would they do all the effort in the first place?
You aren't racing until your breaking shit... My SX is stuffed!!! Point proven
- hentiebez
- 0.4 Bar Boost
- Car: S14
Re: Water to the turbo really needed?
think you just answered your own questionH8rlequinb wrote:Greetings Guys.
- 0.2 Bar Boost
Yea I'm clever like that sometimes...hentiebez wrote:think you just answered your own questionH8rlequinb wrote:Greetings Guys.
- 0.2 Bar Boost
- RB25SX
- Car: R32
Quote from Garrett web page:
"Water cooling is a key design feature for improved durability and we recommend that if your turbo has an allowance for watercooling, hook up the water lines. Water cooling eliminates the destructive occurrence of oil cooking by utilizing the Thermal Siphon Effect to reduce the Peak Heat Soak Back Temperature on the turbine side piston after shut-down. In order to get the greatest benefit from your watercooling system, avoid undulations in the water lines to maximize the Thermal Siphon Effect."
R32 GTR
also, the water lines where used on alot of OEM cars as the winter temps in other countries are generally alot colder than ours, running the water system thru the turbo allows the car's water to reach operating temperature quicker from cold start!
"Growing old is mandatory, growing up is optional"
ex: Audi A3 1.8T 204 kw atw (sold)
ex: VW Mk1 2.0 8v (sold)
- phoenix s14
- Car: S14
- Real Name: Mark Appelgryn
Well here is the equation:
Water to turbo = cooler turbo = cooler compressor = cooler charge = cooler oil
turbo heating water = quicker climb to operating temp
turbo heating water = more strain on cooling system
stock turbo + stock boost level = stock temp
bigger turbo or/and more boost = more strain on cooling system
bla bla bla bla etc etc fit an ally radiator if the temps are too high...
Nissan spent millions on R&D on the design so don't mess with it. Besides if there is water lines currently and you are not fitting a turbo that does not have ports WHY would you take it off... Just dont do other stupid stuff like take off the viscous fan... and if you do add lots of electric ones.
my 2c...
my 2c...
