injector seals???
Rossi-sx
injector seals???
Post by Rossi-sx »
standard CA18det injectors,where is the best place to get a seal kit?
Obsession maybe you can help?
Got a pretty bad fire hazard
Thanx
Reckless driving? When!? Where!?
poizen
Real Name: Mical Mackay
Post by poizen »
its just a viton oring any seal place will hel you and will cost less than R1 each
Rossi-sx
Post by Rossi-sx »
ha ha thats awesome got the perfect contact for that then prob get them for free
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
Current. CA18DET S13
Rossi-sx
Post by Rossi-sx »
well im gonna pull the seals out and take them along as samples and see what he says
nirvash wrote:i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
i think you can
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
i think i'l do the same, just need to find a place in cape town, where abouts are you?
Rossi-sx
Post by Rossi-sx »
Im in East London,if i come right ill let you know
poizen
Post by poizen »
nivash sr20 injectors are side fed so no you cant use the same seals
any bearing or seal place will have these just look in your yellow pages
poizen wrote:nivash sr20 injectors are side fed so no you cant use the same seals
RB25 are side feed injectors
poizen
Post by poizen »
i thought he ment with the ca18 to the sr seals
