	Moderators:  P3g4sus , Daniel , rat , Draco , Riekert
								Rossi-sx
		Posts:  76 Joined:  Mon Jan 18, 2010 3:14 pmCar:  S13Location:  East London
						Post
								by Rossi-sx  Mon Sep 20, 2010 1:36 pm
			standard CA18det injectors,where is the best place to get a seal kit?
							Reckless driving? When!? Where!?
								poizen
		Posts:  2994 Joined:  Sat Apr 12, 2008 2:05 pmCar:  S13Engine:  SRReal Name:  Mical MackayLocation:  Durban, New Germany
						Post
								by poizen  Mon Sep 20, 2010 1:39 pm
			its just a viton oring any seal place will hel you and will cost less than R1 each
								Rossi-sx
						Post
								by Rossi-sx  Mon Sep 20, 2010 2:09 pm
			ha ha thats awesome got the perfect contact for that then prob get them for free
								nirvash
						1.0 Bar Boost
		Posts:  1082 Joined:  Tue Jan 12, 2010 9:38 pmCar:  S13Real Name:  AndreasLocation:  Cape Town
						Post
								by nirvash  Mon Sep 20, 2010 4:29 pm
			i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
Current. CA18DET S13
								Rossi-sx
						Post
								by Rossi-sx  Mon Sep 20, 2010 4:35 pm
			well im gonna pull the seals out and take them along as samples and see what he says
		Posts:  5378 Joined:  Sat Jun 30, 2007 10:38 amCar:  R32Engine:  RBReal Name:  RatLocation:  Margate
						Post
								by rat  Mon Sep 20, 2010 4:54 pm
			nirvash wrote: i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
i think you can
								nirvash
						1.0 Bar Boost
						Post
								by nirvash  Mon Sep 20, 2010 7:21 pm
i think i'l do the same, just need to find a place in cape town, where abouts are you?
								Rossi-sx
						Post
								by Rossi-sx  Tue Sep 21, 2010 7:54 am
			Im in East London,if i come right ill let you know
								poizen
						Post
								by poizen  Tue Sep 21, 2010 7:55 am
			nivash sr20 injectors are side fed so no you cant use the same seals
						Post
								by rat  Tue Sep 21, 2010 8:00 am
			poizen wrote: nivash sr20 injectors are side fed so no you cant use the same seals
RB25 are side feed injectors
								poizen
						Post
								by poizen  Tue Sep 21, 2010 8:01 am
			i thought he ment with the ca18 to the sr seals
