Timing
- poizen
- Real Name: Mical Mackay
you may think all the dots are inline but it very hard to check correctly without all the pulleys off including the bottom one
have you counted the number of teeth on the belt should be
39 teeth from the intake line to the exhaust line then you need to check from the exhaust to the crank which should be about 49 if i remember correctly
