There is a power benefit from 102 IF.
1: Your car is detonation prone
2: You raise the boost to suit the higher octane
3: You advance the timing to take advantage of the higher octane
Of course if you do 2 and 3 above you are pretty screwed if you go back to normal fuel unless you change maps.
