firstly i want to run 2 12" fans, and wanted to know if this is quite easy to do, do they need to be suck or blow fans and are the ones from mr turbo any good, anyone used them?
next, is the standard ball bearing turbo on the s14 sr20 better then the mr turbo non ball bearing T3/T4, what can i get better response from (i would think the ball bearing but dont know) what can i get better power from? also would i get major lag if fitting a T61 ball bearing turbo from again mr turbo, not sure on what brand they stock...
also what intercooler size would be good for a balance between lag/response and power, i'm thinking a 600x300x100 what you guys think about this?
also at which point would it be better to fit a bigger throttle body, and if so what size, looking to get roughly 300whp?85mm???
what sort of power can u get from the stock turbo?
goin to get a z32 AFM, what sort of power are tese good up to?
will ask more questions as they come up,all your help and info will be appreciated guys, lets do it!!
