Opinions:Losing the ABS
- Charlvdw
To loose or not to loose?
hehe.. does not work bad considering its vintage ,was cutting edge when new.. calibration goes out a bit when you stray too far from from the original rim/tyre and brake combos.. dont forget the main advantage of abs is to allow you to manoeuver while braking at max deceleration, because it eliminates slip.. which also mostly gives shorter braking distances.
i could support the argument for space, but weightwise i dont think its worth the effort removing it
i actually relocated my abs when i needed the space instead of removing it..
my 2c
ps.
i remember posting this read some time ago.. interesting read on what abs actually does for you..
http://200sx.za.net/phpBB2/viewtopic.ph ... s&start=30
my 2c
ps.
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
- Charlvdw
300sx wrote:hehe.. does not work bad considering its vintage ,was cutting edge when new.. calibration goes out a bit when you stray too far from from the original rim/tyre and brake combos.. dont forget the main advantage of abs is to allow you to manoeuver while braking at max deceleration, because it eliminates slip.. which also mostly gives shorter braking distances.
i could support the argument for space, but weightwise i dont think its worth the effort removing it![]()
my 2c
ps.
So your sx still have abs then?
- hentiebez
ABS is more dependant on suspension that brake disks due to stiff suspension easily being able to lift up a wheel on uneven ground. Because with the added stiffness and reduced travel of the coil overs you can unload one wheel very easily, if you do this while trying to stop it will kick the ABS in and you litteraly will take about 30 times longer to stop.
New cars with adaptable valve per wheel abs with ebd its not bad at all, but our old school donkey ABS it could be your life on the line.
Guy
Well if you're unloading or lifting a wheel while in an emergency braking situation you've lost traction on that wheel. So I'd rather have the abs working and still be able to steer around whatever you're avoiding rather than sliding or spinning into it.
Possibly the problem is chaep chinese coilovers that aren't suited to road use, especially if they're set up with no droop as you describe. That'll also cause horrible ride quality and some funny weight transfer issues while cornering.
Once again none of this is the fault of the abs. If you have a half decent suspension set up you'll be keeping all the wheels on the ground all the time. Remeber this is a front engined rear wheel drive car.
Race suspension set up on golfs and other fwd things are totally different, they will often want to cock a rear wheel up just to get the car to turn and not understeer.
