LED bulbs
Wanted or for sale
Locked
cape town drfter
LED bulbs
Post by cape town drfter »
Hi guys have LEDs :idea: for reverse light and indicators
R130 for two.Only have two
Slide your ride
MY91 S13 Ca18DET
MY05 Renault Megane RS Turbo
MY10 Freelander TD4 Diesel
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
You have seen my back lights ,Will i be able to run these globes with the smoked lights?
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
I have noticed on other cars that use the LED bulbs for indicators that:
1) It is barely visible under direct sunlight
2) It changes the rate at which the indicator flashes - it flashes quite abit faster
Just FYI.
The tempo is determent by the wattage of the bulb, the lower the wattage the quicker it will flash seeing that you flasher unit is build for a certain wattage.
Toby wrote:I have noticed on other cars that use the LED bulbs for indicators that:
Just FYI.
Well I built my own little lights for the indicators(side ones) ith about 6 LED's per light and they flash constant with the rest of the indicators. I had to however put a resistor or two in drop the voltage.
but they are bright in sunlight too :D
Q-mech
Post by Q-mech »
Charlvdw wrote:The tempo is determent by the wattage of the bulb, the lower the wattage the quicker it will flash seeing that you flasher unit is build for a certain wattage.
Sorry to correct you, but the tempo is determined by the resistance.
Lag? What's that?
174kw s13
162kw G2 turbo
294kw Calibra turbo
cape town drfter
Still have the bulbs.. :?
Slide your ride
MY91 S13 Ca18DET
Locked
