what size to use?
86mm, 86,5mm, 87mm or even bigger?
i am thinking of using VG30dett piston size 88mm^^
should i use HKS sleeves? i think the wall are too thin..
pistons?
- thekoukimonster
- phoenix s14
- Real Name: Mark Appelgryn
as far as I understand VG30 pistons are 87mm. I was looking at them as well for my SR. However the crown is not as recessed as the SR so the compression will go up. You will need to use a thicker head gasket to fit them. They do however fit and other than the top which is different they are the same...
