Digital non contact infrared thermometer
- Charlvdw
Im looking at getting myself one any one else keen? The one im looking at reads from -32C to 560C and go's for R600.
- Speed breeder
- 0.7 Bar Boost
i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!
- Charlvdw
I dont think the tool im looking at is half as complex as the stuff you useoriginal wrote:i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!
Charlvdw wrote:I dont think the tool im looking at is half as complex as the stuff you useoriginal wrote:i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!,i just want the get a temp reading without having to be able to touch the surface i want to measure.
If the unit you are buying does not have an emisivity level then you will get readings that are very far out!!!
the what now?original wrote: If the unit you are buying does not have an emisivity level then you will get readings that are very far out!!!
- Charlvdw
Howmuch is far out? Im not looking for a unit that does a R300k job for R600, as long as it can do what i need it for. If its out by 20C it will be out by that much on all four wheels if i can quote VC.original wrote:Charlvdw wrote:I dont think the tool im looking at is half as complex as the stuff you useoriginal wrote:i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!,i just want the get a temp reading without having to be able to touch the surface i want to measure.
i'z been in ur postingzez, hijacksingz ur threadz!!!Charlvdw wrote:Shit. Thats true as well.rat wrote:charl put vc down, you dont know where he's beenCharlvdw wrote: Thank you
mowahahahahahahahahaha!!!!
