Digital non contact infrared thermometer
Wanted or for sale
Im looking at getting myself one any one else keen? The one im looking at reads from -32C to 560C and go's for R600.
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
so how does it actually work and have you got pics or a name to go and lookup?
Ill post pics tomorow. You aim the lazer at where you want to measure the tempreture example your sump and youll get a temp reading. Its handy when you want to check the temp deference between your cylinders.
original
Newbie
Post by original »
i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!
original wrote:i own and carry out infrared thermography which incorporates the picture and temperature and displays it on my screen!!!! Handy tool but expect to pay around the R300 000 mark!!!! When you get it check that your emmisivity is at 0.96 and your reflective temp is at 20degrees otherwise you will get some very strange readings!!!
I dont think the tool im looking at is half as complex as the stuff you use :) ,i just want the get a temp reading without having to be able to touch the surface i want to measure.
nice for track day tire temp readings too!
hentiebez
Post by hentiebez »
we got one like that at work and it works like a bomb, great little device
original
Newbie
Post by original »
If the unit you are buying does not have an emisivity level then you will get readings that are very far out!!!
original wrote: If the unit you are buying does not have an emisivity level then you will get readings that are very far out!!!
the what now?
Howmuch is far out? Im not looking for a unit that does a R300k job for R600, as long as it can do what i need it for. If its out by 20C it will be out by that much on all four wheels if i can quote VC.
you can quote me!
veecee wrote:you can quote me!
Thank you :)
Thank you :)
charl put vc down, you dont know where he's been
rat wrote:
Thank you :)
Shit. Thats true as well.
Charlvdw wrote:
rat wrote:
Charlvdw wrote: Thank you :)
i'z been in ur postingzez, hijacksingz ur threadz!!!
mowahahahahahahahahaha!!!!
Locked
