Deens
Posts: 42 Joined: Sat Nov 18, 2006 11:22 pm
Post
by Deens » Thu Jan 25, 2007 11:25 pm
Guys, Is there a trick in removing the gear knob on the S13? I tried to twist it off using some good force but it won't budge. The whole lever is starting to twist...I stopped just in case I happen to break something. Anyone??
Charl
Posts: 330 Joined: Mon Nov 20, 2006 3:52 pm
Post
by Charl » Fri Jan 26, 2007 12:41 am
lol. whatch every one go see if their's twists off.
it should twist off, I know mine does. I play with it in trafic.
try tightening it then loosening it again. should break the seal its created...
and widowmaker. don't go make a coment about my knob ok!
200SX Catch my DRIFT?
Toby
Club Founder
Posts: 1874 Joined: Tue Aug 01, 2006 10:44 am
Real Name: Toby Kurien
Post
by Toby » Fri Jan 26, 2007 7:52 am
Charl wrote: I know mine does. I play with it in trafic.
MMMmmmuuuwwwwaaaaahahahahaahahaahahahaa!!!!!
Posts: 7354 Joined: Wed Nov 08, 2006 3:49 pm
Post
by veecee » Fri Jan 26, 2007 7:56 am
you okes are hilarious
stupidshirt
Posts: 26 Joined: Tue Jan 16, 2007 8:33 pm
Post
by stupidshirt » Fri Jan 26, 2007 8:37 am
youre not supposed to remove that part - you need it for drifting
ChemCool
Posts: 2195 Joined: Tue Aug 01, 2006 11:59 am
Post
by ChemCool » Fri Jan 26, 2007 11:26 am
Deens, I had to cut/saw it off
serioussss. Or rather say I had to rape it off.
ChemCool
Post
by ChemCool » Fri Jan 26, 2007 11:28 am
it is now close to a short shifter
Posts: 5975 Joined: Thu Oct 12, 2006 12:56 pm
Post
by Gary57 » Fri Jan 26, 2007 1:54 pm
Is a short shifter actually shorter or does it just reduce the throw but stay the same height??
ChemCool
Post
by ChemCool » Fri Jan 26, 2007 2:00 pm
Gary I was only joking about short shifter, because I dont know the answer. Good question and may be some one else will lighten up the answer.
widowmaker
Posts: 3051 Joined: Wed Aug 02, 2006 9:50 am
Real Name: Walter
Post
by widowmaker » Fri Jan 26, 2007 3:07 pm
short shifter - the actual length that you can see is the same, but - what you can't see is the ball and piepietjie that does the actual shifting. The longer the piepietjie, the shorter the top part (where your hand attaches) has to move to get the piepietjie to change the gears beneath. Great mod to have... on my shopping list
i cant describe things on a friday afternoon
Toby
Club Founder
Post
by Toby » Fri Jan 26, 2007 3:11 pm
widowmaker wrote: The longer the piepietjie, the shorter the top part (where your hand attaches)
Gawd.... I'll keep my long piepietjie, thank you very much
Deens
Post
by Deens » Fri Jan 26, 2007 4:38 pm
With the short shifter the position of the pivot point is raised thus giving you less leverage at the top to make the same travel below the pivot point. In the old Escort 1600 Sport & RS2000 they added a distance piece to achieve this, which gave a very nice feel when changing gears. Windows is quite right, but explained differently.
Deens
Post
by Deens » Sun Jan 28, 2007 7:10 am
Yes, it does twist off. I battled but eventually removed it.
