Gear Knob
Deens
Gear Knob
Post by Deens »
Guys, Is there a trick in removing the gear knob on the S13? I tried to twist it off using some good force but it won't budge. The whole lever is starting to twist...I stopped just in case I happen to break something. Anyone??
Charl
Post by Charl »
lol. whatch every one go see if their's twists off.
it should twist off, I know mine does. I play with it in trafic.
try tightening it then loosening it again. should break the seal its created... :idea:
and widowmaker. don't go make a coment about my knob ok! :wink: :lol:
200SX Catch my DRIFT?
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
Charl wrote:I know mine does. I play with it in trafic.
MMMmmmuuuwwwwaaaaahahahahaahahaahahahaa!!!!! :lol: :lol: :lol:
you okes are hilarious :lol:
stupidshirt
Post by stupidshirt »
youre not supposed to remove that part - you need it for drifting
ChemCool
Post by ChemCool »
Deens, I had to cut/saw it off :shock: serioussss. Or rather say I had to rape it off.
COOLER, FASTER, LIGHTER
ChemCool
Post by ChemCool »
it is now close to a short shifter :lol: :lol:
Is a short shifter actually shorter or does it just reduce the throw but stay the same height??
ChemCool
Post by ChemCool »
Gary I was only joking about short shifter, because I dont know the answer. Good question and may be some one else will lighten up the answer.
widowmaker
Real Name: Walter
Post by widowmaker »
short shifter - the actual length that you can see is the same, but - what you can't see is the ball and piepietjie that does the actual shifting. The longer the piepietjie, the shorter the top part (where your hand attaches) has to move to get the piepietjie to change the gears beneath. Great mod to have... on my shopping list
i cant describe things on a friday afternoon
Toby
Club Founder
Post by Toby »
widowmaker wrote:The longer the piepietjie, the shorter the top part (where your hand attaches)
Gawd.... I'll keep my long piepietjie, thank you very much :D
Deens
Post by Deens »
With the short shifter the position of the pivot point is raised thus giving you less leverage at the top to make the same travel below the pivot point. In the old Escort 1600 Sport & RS2000 they added a distance piece to achieve this, which gave a very nice feel when changing gears. Windows is quite right, but explained differently.
Deens
Post by Deens »
Yes, it does twist off. I battled but eventually removed it.
