Clutch gone
Clutch gone
Post by Ero_sennin »
How easy is it to change the clutch cable on a S13 mine seems to have ended its life. :shock:
poizen
Real Name: Mical Mackay
Post by poizen »
well there is no clutch cable its hydrolic clutch unless you mean the hydrolic pipe
whats wrong with your clutch
I was afraid of that :shock: when I press the clutch pedal it is very easy to press, and the clutch does not disengage.
Check for leaks.
I think your piston is messed up.
It doesnt cost alot to fix if that s the problem. Like R50
I didn't see any leaks, there is fluid in the reservoir... guess its off to the mech again
dont be lazy - do it yourself!
get the ou vrou to "pump", and get under the car to see that the slave piston is moving and that the clutch fork is moving with it!
Guy
Post by Guy »
My clutch cable is missing!! ;)
poizen
Post by poizen »
Guy wrote:My clutch cable is missing!! ;)
no they joined it to your hand brake
Puls0nic
Post by Puls0nic »
dude, thats a brilliant idea for when ur drifting.... Hmmmm
Future fence sitter
Ero_sennin wrote:I didn't see any leaks, there is fluid in the reservoir... guess its off to the mech again
Open up the lid for the resevoir and check what color is the the brake fluid.
About 3 weeks ago I cooked the fluid so if the fluid is black its cooked and you need to do a flush. :wink:
any contaminated fluid will look black, not just cooking it, but even if water got into the stuff.
i dont think so dude...
You probably right but If you remember when we had poker night, my car over heated. I think it got cooked at that time.
[smilie=200sx_offtopic.gif]
I thought I blew my H/Gasket but when I took it out it was still fine. I replaced it anyways.
I dunno what could of caused it to overheat cos it never happened before or maybe it was scared of the other cars there.
Personally I think the heater radiator had something to do with it
it was sort of brown I think, but even so how does it work one moment then all of a sudden just stop
poizen
Post by poizen »
a piston is bypasing fluid so mayb a o ring has broken off
