Turbo intake piping
Turbo intake piping
I am making an aluminum turbo intake pipe, CNC bent etc. I want to know what intake size to use. I figure that you should use the same size piping as the intake throat on the turbo... what you think??
Skidd
Post by Skidd »
Usually 57mm is good for up to 2 bar boost. You will need to check the size on everthing else and get some silicon hosing to match it up to the other components.
2002 Astra Coupe Turbo - 131.8kw and 291nm ATW
Looking for S13 200SX
Dislex666
Post by Dislex666 »
are you talking about the pipe from the airfilter to the turbo?
I got this funky stuff from the calibrator - sorta checks like ducting ;) apparently it's dual layer etc etc etc and 4" in diameter :D (my compressor side is 4" into the turbo :) )
Yes the pipe from the airfilter to the turbo. I think 76mm would be a good bet, plus you can get 76mm-63mm reducers easily.
Skidd
Post by Skidd »
ok cool, I know which pipe now.
The blue piping is the one you talking about. You can go wild on this side of things. The red pipeing on the other hand is a clalculated size, too big and you get too much turbo lag, too small and you strain the turbo a bit. Like I said 57mm is fine for up to 2 bar boost on 4 cylinder turbo motors.
Post by Vlade »
stock intake size is 63mm your not gonna gain anything by making it bigger... I got some 63mm reinforced flex hose there... works fine.
ChemCool
Post by ChemCool »
Gary, explain to me why you want to do this? Phinx also mentioned this intake pipe falling flat during operation. Is that really the situation and if so, how do you see that happening when? Is the spring inside that pipe useless or what??
COOLER, FASTER, LIGHTER
that intake pipe is hugely restrictive!! when i changed mine to stainless it gave 0.1 bar extra boost and i bet a damn side lower air temps!! i am also getting rid of the MAF so the air filter wont sit very nicely.
ChemCool
Post by ChemCool »
Awesome, I underst that. Like it.
