Turbo Seals Burnt
Turbo Seals Burnt
Hi guys I need some expert advice, is it possible that if you weld on a turbo that the seals can collapse when it comes under boost ?
Re: Turbo Seals Burnt
Jean....WELD ON A TURBO??????EightySix wrote:Hi guys I need some expert advice, is it possible that if you weld on a turbo that the seals can collapse when it comes under boost ?
What did you do?
Shouldn't you bolt that on???
Hehe mate if you have the time one day you have to come have alook at what we had to do to make this turbo fit mate.
Firstly I had to modify the bracket for the wastegate because it didn't go with the way I had to turn the turbo to fit on to the manifold.
Secondly the down pipe flange did not fit on the turbo and I had to get a new flange made and on that the down pipe needed to be welded on, I DID NOT DO THIS MYSELF and without thinking the guy welded the pipe on without taking it off the turbo.
Then when I drove it the seal collapsed and the turbine is loose in the barrel of the turbo. This is what I think happened, I still have to confirm this by taking the turbo off AGAIN
Holy crap, that sounds like a mess.EightySix wrote:Hehe mate if you have the time one day you have to come have alook at what we had to do to make this turbo fit mate.
Then when I drove it the seal collapsed and the turbine is loose in the barrel of the turbo. This is what I think happened, I still have to confirm this by taking the turbo off AGAIN![]()
Shout if you need some help.
