Hydraulic clutch and Gearbox problem
- Speed breeder
- 0.7 Bar Boost
Almost everything done on my car... now I see the hydraulic system has a problem. Have bled the system, but can't seem to get the air out.
Sounds like a seal has gone, but I don't know.
It is now at the point where fluid doesn't even come out of the bleeder.
There are also no visible leaks on any of the lines
The clutch pedal does not return on its own
Has anyone had this problem before?
Couple of questions
What is the bleeding order? Master cylinder, then the extra bleeder on the clutch connector, then the operating cylinder?
Does anyone have extra parts lying around?
The next issue, after draining and refilling the gearbox, I seem to have a leak on the gasket where the spickot is in the gbox.
Can I only find these gaskets at the agents?
Couple of questions
- Speed breeder
- 0.7 Bar Boost
- Speed breeder
- 0.7 Bar Boost
lol. its good I still have a sense of humour left.
There is fluid in the master cylinder, but it does not seem to be moving.
When I first started bleeding the system got fluid, and got less the more we bled until it finally just stopped. Topped up the reservoir throughout the process.
Should the pedal come up on its own?
- Speed breeder
- 0.7 Bar Boost
Resolved the issue.
Very strange.
Problem was that the operating cylinder did not move and no hydraulic fluid came out of any of the bleeders.
Removed master cylinder, distribution block and operating cylinder.
Cleaned whole system
Decided to remove the distribution block entirely as well
Nothing seemed to be wrong with the seals, but still did not operate after fitting and bleeding.
Bought kits from MIDAS for operating and master cylinder - part numbers to be posted - R62.00 for everything including new pistons and seals.
"Honed" cylinder walls with 2000 sanding paper
Replaced all pistons and seals
Bled system again.
Start and drive
Very strange.
Bled system again.
Start and drive
- Speed breeder
- 0.7 Bar Boost
but I would appreciate it if you could post them for me.
Want to do this tomorrow before if stuck without a clutch again.
- Speed breeder
- 0.7 Bar Boost
- Speed breeder
- 0.7 Bar Boost
- Speed breeder
- 0.7 Bar Boost
- Drillergy
- Real Name: Darryl
I paid R200 for it. I dont think its the original one. Its an autoquip part.Speed breeder wrote:how much was the hardbody master cylinder and where did you get it?
The Hardbody master cyclinder doesnt have the bleed nipple on the cylinder and it is a side feed.
That distribution block and loop had me for hrs.
Do you know whats the point of it?
