ReeceZ
Posts: 1876 Joined: Sun Jan 20, 2008 1:36 am
Post
by ReeceZ » Wed Nov 19, 2008 6:09 pm
Howzit guys, has any1 used this turbo on a CA motor with .48 exhaust housing, engine with stock internals. What's your views, comments, suggestions... thanks
Posts: 5723 Joined: Thu Aug 03, 2006 8:32 am
Post
by Draco » Thu Nov 20, 2008 7:14 am
I haven't but I knew the owner of a bakkie with a ca18det with that on, everybody said he would have serious lag but the .48 housing helped a lot, it was still slightly laggay but not close to making it a bad move....
Lag remained close to the standard turbo lag, o and it also depends on what the exzaust wheel is made of.....
ReeceZ
Post
by ReeceZ » Thu Nov 20, 2008 8:28 am
Howzit draco, do you know how his engine internals held up
Post
by Draco » Thu Nov 20, 2008 9:39 am
His engine had stock internals, he just had a knife edged crank and lightened flywheel + balancing and boosted 1.2 bar,it held up for almost 2 years, he broke it in a drag race at tarlton because he kept going in 3rd to over 9000 revs when he hit a bearing because of that.
ReeceZ
Post
by ReeceZ » Thu Nov 20, 2008 11:52 am
Sounds impressive. Do you what kind of power he made? Wanted this turbo as I'm thinking of using it on my CA while its still around, then move it over when i get an SR motor
Post
by Draco » Thu Nov 20, 2008 12:18 pm
Sorry no....
RB25SX
Posts: 1423 Joined: Tue May 06, 2008 4:38 pm
Post
by RB25SX » Thu Nov 20, 2008 12:21 pm
That turbo works well on SR20 with not too much lag. Shouldnt be too bad on CA18.
ReeceZ
Post
by ReeceZ » Thu Nov 20, 2008 12:57 pm
Besides the .48 on the exhaust side. What other specs should I use to try to minimise lag as much as possible and get full boost around 4000rpm.
Posts: 7354 Joined: Wed Nov 08, 2006 3:49 pm
Post
by veecee » Thu Nov 20, 2008 3:14 pm
NOS
ReeceZ
Post
by ReeceZ » Thu Nov 20, 2008 3:18 pm
Can't, I'm trigger happy
Post
by veecee » Thu Nov 20, 2008 3:19 pm
programmable NOS, no need for that itchytriggerfinger - negra!
Posts: 5378 Joined: Sat Jun 30, 2007 10:38 am
Post
by rat » Fri Nov 21, 2008 9:04 am
will it really help with lag?
Post
by Draco » Fri Nov 21, 2008 9:29 am
You will be boosting before that......if you wanna help a little, instead of going with 76mm boost pipes, use 63.
ReeceZ
Post
by ReeceZ » Fri Nov 21, 2008 10:53 am
Yo rat, u also thinking of goin t3/t4
Post
by rat » Fri Nov 21, 2008 11:05 am
na my turbo is a .89 so a bit of lag but maybe nos
