TURBINE SAYS: 381-24 GARRETT 0.86 T694
Looks like this
http://forums.freshalloy.com/showthread.php?t=154091
What turbo is this? And advice needed
- rat
- Real Name: Rat
- rat
- Real Name: Rat
From this page it looks like a GT2860RS with the bigger .86 turbine?
Just cost me R2670 for a recon so it cant be a ball bearing one, i was told when i got the car that it was a T28 in there so now i know why i got so much lag!!!!!
http://www.clubgti.com/forum/archive/in ... 26504.html
Yep Its a GTI-R turbo
You have a very good turbo there, The .84 Exhaust housing means so nice Top end power , I will be switch over to a .84 Exhaust housing soon aswell
It will be laggy on a CA or even a SR
Turbine A/R is .86, compressor A/R is .60 (T3 Super 60 housing)
- rat
- Real Name: Rat
so PFB what can i boost on that turbo? any ideas on mods for the car or shall i change the turbo or even think about a sr?Pinkfluffybunnys wrote:Yep Its a GTI-R turbo
The turbo at around 10 - 14 psi should Max you injectors out by a good margin
Its a good turbo most people on the club wont get close to maxing that thing out but It will be laggy with the .84 housing but will be very efficient it depends on what you want from you car.any ideas on mods for the car or shall i change the turbo
To lower the lag you will need a good tubular header, Good Sized exhaust system and intake system a Good tune will also bring it down and there are a few other things but it will still boost a bit late but go hard.
Its up to you about this , Its a lot of money for 189cc extra but once all the swapping has been done and all the money has been spent at least parts will be a little cheaper[/quote]or even think about a sr
