Turbo flange question
Ive made my own turbo flange i want to know does the wastegate side on the turbo also has to have an outlet pipe to it or can i just cut n passage to the turbine side that the gas can go through there
Hey?
ok you made a flange from the exh mani to the turbo correct?
then you'll need a downpipe for the exh side of the turbo. is the wastegate internal?
