Ok so I am looking at building a diffused down pipe as I currently have a bell-mouth. Now the bell-mouth I have is 76mm and I cant fit a 76mm diffused downpipe because of the size of the turbine housing exit.
So I want to go with a 63mm for the main and 38mm for the WG. The 38mm pipe will join the 76mm about 300mm away from the turbo.
Problem is how do I join the 63mm-76mm nicely with the least restriction as possible??
Any one done this mod before??
63mm - 76mm
63mm - 76mm
The Only way you going to have enough space is if you go the same way I did 63 DP with a the 38mm joining the exhuast down stream.
I would like to go 76mm DP with the screamer but like you said there is no space.
