2 exhaust cams on ca18det
Hey guys i saw an article about a guy that used an ca18de exhaust cam on the intake side of a ca18det because the exhaust cam has 0.7mm more lift than the intake cam and he gaind 15 kw
I know of this mod yes, but 15kW...a bit ambitious maybe.
I know Oscar(Tanaka) is running 186kWfw with CA18DE cams(Intake and exhaust). But he has got a HUGE FMIC and a 76mm downpipe and exhaust system, and then a few other tweaks and small things like an HKS mushroom filter and and and...
I dont think on a stock CA18DET will gain 15kW out of that mod.
Dude your running a CA18DE so you have the Jap Spec Cam already.
This is a normal international mod when you cant get hold of a CA16DE cam or CA18 cam also you will need cam gears to get the cam timing correct.
Also the most seen is 12RWKW on a pretty well worked CA18
LOL don't under-estimate cams but I have never seen any dyno done before and after with more then 12 RWKW most gain in mid-range with the CA18 cam.
This has been covered a million times so I think everything has been said
I will post the link , It stored is some file somewhere
