Flywheel
Uhm...well that wont make sense to me since the CA18DET already have no torque below 3000rpm, and then getting a lighter fly which means that it needs more revs to make more torque...so if i'm thinking right here it will mean that you have to pull away at every traffic light in boost????
Gary??
VC??
What do you say?
Gary??
VC??
What do you say?
Yes the CA18 have no torque. My flywheel is so light that I have a lumpy idle below 1000rpm, its idles at 800rpm but at 14:1 AFR. Yes the lighten flywheel makes the motor feel gutless but definately makes it rev quicker. I would still do it every day of the week.
A flywheel doesnt make torque hey, it just retains it. So you will feel less torque when you going say up a a hill, so just put your foot down a bit more.
You will have a drop in torque because when the motor falls off its torque curve the flywheel doesnt have enough inertia to release so you feel a drop in torque.
Agreed lets make it easyier, ThanksLets make it easy for them to understand, its like a pendulum without the weight at the bottom, then its not gonna move from side to side or if it does its gonna move a little and a lot of force will be needed to move it.
http://www.geocities.com/motorcity/7177/flywheel.html
accelerating a vehicle the engine not only has to push the total mass of the car but the internal components of the engine need to be accelerated also. This tends to absorb more power as the extra power is used accelerating the internal mass of the engine components and is why a motor accelerating on a dyno will produce less power than at constant revs. Also it must be remembered that the rate of acceleration on the engine internals is much greater that the rest of the car. This would then suggest that by lightening the flywheel, less power would be required to accelerate it and therefore more power would be available to push the car along.
Now, it may seen unbelievable that by removing a few kilos from the flywheel a noticeable difference to a 1000+ kg cars acceleration will be made. In fact the difference is quite noticeable and the secrete behind this is hidden within the gearbox. Everyone knows that cars accelerate at a greater rate in low gears, this is because a cars gear box basically a mechanical leaver and just like when using a leaver to lift a heavy object, the gearbox reduces the mass of the car that the engine sees. For example, in first gear an engine will see the cars mass as only around say 100kg but the engine internal mass would still remain around 20+kg .
It is now easier to see were the extra performance comes from when you lighten a flywheel. In some cases, and not necessarily extreme ones, you could effectively " lighten " a car by 20% in first gear just by removing mass from the flywheel. As the gear used increases this "lightening" effect is reduced. This is why carÉs acceleration reduces in higher gears, to almost no effect in top gear. Great for drags and tight race tracks but will not increase a cars top speed one bit.
For the engineers among us.
http://www.physicsforums.com/showthread.php?t=160968
- mario_200sx
