s13 brake problem
ettienne
s13 brake problem
Post by ettienne »
Hi guys, on my s13 std front brakes theres a metal plate that holds the brake disk in place, i think its called a ratlle plate or somthing. My front right is missing, any idea where i can get another. plz
the wheel studs and bolts hold the disc in place. :?
the big round plate is a dust cover.
you should place a wanted ad in in the classifieds section but dont hold your breath :lol: :lol:
Post by Ero_sennin »
why would you think its called a rattle plate?
It doesn't rattle as far as I know. :shock:
ettienne
Post by ettienne »
Sorry guys my bad, i meant holds the brake pad in place. It was late.
Doctor G
0.7 Bar Boost
Post by Doctor G »
ettienne wrote:Sorry guys my bad, i meant holds the brake pad in place. It was late.
those are called shims.
no idea where you can get them. Usually the agents are knobs and only sell it with the caliper rebuild kit for $$$$$$.
But there are a lot of spare s13 brakes on this forum, so maybe someone can hook you up.
HancoB
Post by HancoB »
Don't you get those with a new set of pads???
ettienne
Post by ettienne »
It doesnt come with new brake pads as far as i know if some1 knows otherwise please fill me in. the agents will sell that plate but they want R800 for it.
HancoB
Post by HancoB »
I'm sure you get them with new pads. Even with my golf I got them with a new set of pads.
HancoB
Post by HancoB »
But then again its Nissan...
widowmaker
Real Name: Walter
Post by widowmaker »
i think they wanna charge you for the disk protector/dust plate around the rotor - these lil thingies shouldn't cost more than 20c - but ya i got them with pads
I am missing mine for the Z32 calipers.
ettienne
Post by ettienne »
i wonder if theres any1 out there that recently bought a set of pads and can tell us if it came with that plate.
Doctor G
0.7 Bar Boost
Post by Doctor G »
There seems to be some confusion here..
Ettiene are you talking about the plates that fit at the flat surface behind the pad?
or
the little shims that hold the tips of the brake pads on each end? The shim is the one that holds both pads at the top and bottom.
The flat plates behind the pad should come with a set of new brake pads. If it doesn't it's no big deal.
But the shims on the end hold the pad in in position.
Gary on the Z32 calipers it uses pins that go through the caliper and through holes in the pads. So it doesn't use the metal plate shims afaik. They do sell the pins seperately.
mario_200sx
Post by mario_200sx »
post a pic of what your talking about...
I think he is talking about the anti rattle plates that sit at either end of the pads (top and bottom).
Yes DocG,I made my own pins. The anti rattle plate the goes over the top of the pads is what I am missing, cross shaped thin plate. I am using silicone now, works 100%.
