Is dicktator any good
Hi guys im looking at buying a management to run on my CA for a couple of months and then RB26
The dicktator seems good value for money and i know that
Riaan is also using it on his Rb25
I have had good reports and bad so far so....what do i do
Im looking for something that guys are familiar with and so far alot of guys say dicktator
I know gary diagrees though
Is anyone here using dicktator
Donny here is nice long review with load of arguements in it, you decide.
http://www.zoopedup.net/index.php?showt ... =Dicktator
- Stephen Swanepoel
- 0.5 Bar Boost
I am running a Dictator in my Girfriends Toyota MR2 (3sgte motor)
No problems what so eva, pushing 140kw on the wheels and that @ 0.4bar boost.
I honestly think that the management system is only as good as the tunner tuning the car. An ecu can only do what you tell it to do. So if its not right it wasn't tuned right.
the engine has its own harness which is connected to the ECU.
the ABS has its own computer, in the driver side B pillar.
and the rest of the cars functions are controlled by wires, relays, switches, etc. the engine ECU also has a function that turns off the aircon at full throttle.
but other than these things, it should be alright to just yank everything to do with the engine out.
i'm going to do that soon!
You will trust a R2000 ECU to run a R20 000 modification?? Average EMS will cost about R10 000, what makes you think that a R2000 can do the same??
Dicktator uses interpolation (as does every EMS) to get the load sites between the cells filled in by the tuner, 5 load sites between 100% vacuum and 1 Bar (or even 1.5Bar) is definately not enough.
