Hi all
Any suggestion on how many fans and what sizes i should fit and do i need to install a temp.sensor to activate them or can i pick that up elsewhere?
I saw some picks with elecktric fans installed and couldnt believe the space you gain with that.
Elecktric Fans?
well i actually tested this with n1smo the other day, and although derek is correct, the amps drawn drop until they reach about 7-9 amps.
so the fans we tested peaked at 15 amps initially, they settled over about 1 minute of testing to around 7-9 amps.
we couldn't understand why the fuse they wired in kept melting until we tested it and then installed a 20 amp fuse!
the 2X12" fans fit nicely on our radiators.
and you should definintely splice into the aircon switch somehow because you'll have to have at least one fan come on when the aircon is switched on.
other than that its fairly simple, and it works well.
