Wheel stud 60mm with 13mm spline.
- Charlvdw
Like the subject says. 12 X 1.25 X 60 with 13mm spline. Anyone?
- Engine: VG
- Real Name: Tony
Re: Wheel stud 60mm with 13mm spline.
Check out this post...by BigKris
Reliable Bolt and Nut, Terrace rd , Edenvale. Any stud, bolt in all lengths up to 80mm available, 10mm , 12 ,, 14 and 16mm diameter.
Been buying my wheel bolts and studs from them for years already.
- Charlvdw
Thanx Tony, will check it out.antman wrote:Check out this post...by BigKris
- Engine: VG
- Real Name: Tony
Charl...heres the number,,added it to my address.
71 terrace road edenvale 0116097964
- fuzz123
- Real Name: Jacobus
I had a go with reliable bolt and nut and sadly it was not correct, I wanted 14mm splines and the local manufacturers ended up making it 13.7mm which is just not enough for it to get any bite in the hole.
I would honestly suggest that you take a vernier with upon collection to make sure you get the right sizes before leaving the store.
I had a good run with rezlo in PE which supplied the correct sizes right off the bat. Just google rezlo auto works.
- Charlvdw
Thanx, just need to get one by Friday.antman wrote:Charl...heres the number,,added it to my address.
- Charlvdw
What did you need 14mm for?fuzz123 wrote:I had a go with reliable bolt and nut and sadly it was not correct, I wanted 14mm splines and the local manufacturers ended up making it 13.7mm which is just not enough for it to get any bite in the hole.
- fuzz123
This was for the 200sx s14 95 model. The previous owner used spacers in the front wheels when he changed the mags but never bothered to get new studs. When I changed the front breakes I realized I was driving on borrowed time as theses studs were done for, stripped almost completely.Charlvdw wrote:What did you need 14mm for?fuzz123 wrote:I had a go with reliable bolt and nut and sadly it was not correct, I wanted 14mm splines and the local manufacturers ended up making it 13.7mm which is just not enough for it to get any bite in the hole.
