Wheel stud 60mm with 13mm spline.
Like the subject says. 12 X 1.25 X 60 with 13mm spline. Anyone?
antman
Engine: VG
Real Name: Tony
Re: Wheel stud 60mm with 13mm spline.
Post by antman »
Check out this post...by BigKris
Reliable Bolt and Nut, Terrace rd , Edenvale. Any stud, bolt in all lengths up to 80mm available, 10mm , 12 ,, 14 and 16mm diameter.
Been buying my wheel bolts and studs from them for years already.
antman wrote:Check out this post...by BigKris
Thanx Tony, will check it out.
That's like stock just longer?
antman
Engine: VG
Real Name: Tony
Post by antman »
Charl...heres the number,,added it to my address.
71 terrace road edenvale 0116097964
rat wrote:That's like stock just longer?
Jip.
fuzz123
Real Name: Jacobus
Post by fuzz123 »
I had a go with reliable bolt and nut and sadly it was not correct, I wanted 14mm splines and the local manufacturers ended up making it 13.7mm which is just not enough for it to get any bite in the hole.
I would honestly suggest that you take a vernier with upon collection to make sure you get the right sizes before leaving the store.
I had a good run with rezlo in PE which supplied the correct sizes right off the bat. Just google rezlo auto works.
antman wrote:Charl...heres the number,,added it to my address.
Thanx, just need to get one by Friday.
fuzz123 wrote:I had a go with reliable bolt and nut and sadly it was not correct, I wanted 14mm splines and the local manufacturers ended up making it 13.7mm which is just not enough for it to get any bite in the hole.
What did you need 14mm for?
fuzz123
Real Name: Jacobus
Post by fuzz123 »
This was for the 200sx s14 95 model. The previous owner used spacers in the front wheels when he changed the mags but never bothered to get new studs. When I changed the front breakes I realized I was driving on borrowed time as theses studs were done for, stripped almost completely.
