300zx front 4 pot Calipers/discs **SOLD**
antman
Engine: VG
Real Name: Tony
Post by antman »
Hi..this set is sold.
I have a set of 300zx Z32 front 4 pot aluminium calipers with pads and a set of discs with 5% wear.
Nice brake upgrade.
R3500
082 8766837
Re: 300zx front 4 pot Calipers/discs
Are these the 30mm wide calipers?
antman
Engine: VG
Real Name: Tony
Post by antman »
Hi...yes they are the 30mm ones.They come with vented 25mm rotors.
If only I had the cash...
Laters Riekert
Enzio
Post by Enzio »
antman wrote:Hi...yes they are the 30mm ones.They come with vented 25mm rotors.
That doesn't sound right, the discs should be 280x30mm.
Also, do you have the rears for sale as well?
If the calipers has the ribs then its 30mm
antman
Engine: VG
Real Name: Tony
Post by antman »
The calipers have the ribs and have the 30mm wide access, they came off the working car and the discs are vented 25mm, same as my 1990 300zx TT.
The rears are sold on Saturday.
Enzio
Post by Enzio »
If the caliper is 30mm wide, then it is the calipers from a NA 300ZX that uses 26mm wide discs.
Calipers for the 30mm discs should have about 35mm wide opening for disc.
Thus they cannot be the same as your TT brakes, unless somebody downgraded them at some stage.
Its a shame, I was interested in the rears....oh well, the wait continues.
Sounds like TT calipers to me.
Enzio
Post by Enzio »
Antman, post a pic with a ruler or tape measure over the slot in the caliper for the disc. That will stop all speculation.
antman
Engine: VG
Real Name: Tony
Post by antman »
Gentlemen...I have measured the caliper slot using a digital vernier.....30mm
Enzio you may be correct.....Anyone want photographic evidance?
Still want them. :(
Laters Riekert
antman wrote:Gentlemen...I have measured the caliper slot using a digital vernier.....30mm
Then these are to suit 26mm discs, thank you but not what I am after.
