300zx front 4 pot Calipers/discs **SOLD**
- 0.3 Bar Boost
- Engine: VG
- Real Name: Tony
Hi..this set is sold.
I have a set of 300zx Z32 front 4 pot aluminium calipers with pads and a set of discs with 5% wear.
Nice brake upgrade.
R3500
082 8766837
Nice brake upgrade.
R3500
082 8766837
Re: 300zx front 4 pot Calipers/discs
Are these the 30mm wide calipers?
- 0.3 Bar Boost
- Engine: VG
- Real Name: Tony
Hi...yes they are the 30mm ones.They come with vented 25mm rotors.
If only I had the cash...
Laters Riekert
Laters Riekert
That doesn't sound right, the discs should be 280x30mm.antman wrote:Hi...yes they are the 30mm ones.They come with vented 25mm rotors.
Also, do you have the rears for sale as well?
- Drillergy
- Real Name: Darryl
If the calipers has the ribs then its 30mm
- 0.3 Bar Boost
- Engine: VG
- Real Name: Tony
The calipers have the ribs and have the 30mm wide access, they came off the working car and the discs are vented 25mm, same as my 1990 300zx TT.
The rears are sold on Saturday.
If the caliper is 30mm wide, then it is the calipers from a NA 300ZX that uses 26mm wide discs.
Calipers for the 30mm discs should have about 35mm wide opening for disc.
Thus they cannot be the same as your TT brakes, unless somebody downgraded them at some stage.
Its a shame, I was interested in the rears....oh well, the wait continues.
- Drillergy
- Real Name: Darryl
Sounds like TT calipers to me.
Antman, post a pic with a ruler or tape measure over the slot in the caliper for the disc. That will stop all speculation.
- 0.3 Bar Boost
- Engine: VG
- Real Name: Tony
Gentlemen...I have measured the caliper slot using a digital vernier.....30mm
Enzio you may be correct.....Anyone want photographic evidance?
Still want them.
Laters Riekert
Laters Riekert
Then these are to suit 26mm discs, thank you but not what I am after.antman wrote:Gentlemen...I have measured the caliper slot using a digital vernier.....30mm
