NOSSSSS
I'm not really a Fan of NOS but as long as the fueling is handled and the shot isn't to great the Set-up is viable.
Why don't you spend the money on a bigger turbo set-up nice IC and Management and have perma-NOS
AFAIK, a direct kit just means that each port will have a NOS and fuel injector.
so a 4 pot motor will have four NOS injectors.
cant remember if that means that you will run a dry or wet system, but a quick scan on google, or wiki, will clear that up!
or any of the car mod forums for that matter!
Nos will work perfectly as long as its done properly. multiple fogger systems are expensive and complex and not needed unless you are going for huge power.
The Sentra in my shop had a multiple fogger system and melted an exh valve 3 times (No 3) after reverting to a single fogger no more issues.
With a DET motor running 0.7bar and 155kw I was making 220kw with nos.
At 240kw the limit of the std head bolts was found, besides the missing welch plug and bent conrod from water ingestion the rest of the motor was still perfect and good for plenty more km.
However it was not your R2000 kit. I was running a progressive system I developed using a SMT6 to map the Nos flow and retard timing during nos operation.
Plus a bottle heater and pressure gauge to keep the pressures consistent.
