ca18det problems
Re: ca18det problems
plugs i got are NGK bcp6es
NIZAN-R
- Real Name: Renier
get the plugs (part no) rat posted
ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
Got spare if you need.smash!! wrote:ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
Sometimes things are simple isn't it...
Hey guys so i replaced the spark plugs with bcpr6es just to find a crack on one of coil packs its a samall crack in the yellow stuff could that be the problem ?? If so where can i get a new coil and how much ? Ur help will be greatly appriciated
I really hope so goin to get a price from the agents on sat . just praying its not an arm and a leg to fix
Went to nissan today R 2000 for just the top part of the coil the resistor part is extra.. goping to find one that some one has from a spare motor . know a few guys from tarlton that might be able to help
