ca18det problems
Re: ca18det problems
plugs i got are NGK bcp6es
- Real Name: Renier
get the plugs (part no) rat posted
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
Got spare if you need.smash!! wrote:ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
Sometimes things are simple isn't it...
Hey guys so i replaced the spark plugs with bcpr6es just to find a crack on one of coil packs its a samall crack in the yellow stuff could that be the problem ?? If so where can i get a new coil and how much ? Ur help will be greatly appriciated
I really hope so goin to get a price from the agents on sat . just praying its not an arm and a leg to fix
Went to nissan today R 2000 for just the top part of the coil the resistor part is extra.. goping to find one that some one has from a spare motor . know a few guys from tarlton that might be able to help
