ca18det problems
smash!!
Real Name: Ash
Re: ca18det problems
Post by smash!! »
plugs i got are NGK bcp6es
BcpR6es
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
get the plugs (part no) rat posted
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
smash!!
Real Name: Ash
Post by smash!! »
ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
smash!! wrote:ok called midas now plugs R114.24 ill get them later on today and will let you guys know if it helps also last night i removed the idle control valve and the cold start valve the car starts straight away no problems just a miss but im gueesing that its got to be the plugs.
Got spare if you need.
Sometimes things are simple isn't it...
smash!!
Real Name: Ash
Post by smash!! »
Hey guys so i replaced the spark plugs with bcpr6es just to find a crack on one of coil packs its a samall crack in the yellow stuff could that be the problem ?? If so where can i get a new coil and how much ? Ur help will be greatly appriciated :(
I am sure someone has a spare coil pack for you.
smash!!
Real Name: Ash
Post by smash!! »
I really hope so goin to get a price from the agents on sat . just praying its not an arm and a leg to fix
About R1500 from Nissan.
smash!!
Real Name: Ash
Post by smash!! »
Went to nissan today R 2000 for just the top part of the coil the resistor part is extra.. goping to find one that some one has from a spare motor . know a few guys from tarlton that might be able to help
