T28 for sale.
Wanted or for sale
Locked
n1smo200sx
T28 for sale.
Post by n1smo200sx »
GTR t28 for Sale. 0.6 blade 0.49 exhaust housing.Ceramic blade.Good condition.R3000.
Re: T28 for sale.
n1smo200sx wrote:GTR t28 for Sale. 0.6 blade 0.49 exhaust housing.Ceramic blade.Good condition.R3000.
whats a GTR T28? do you mean GTiR?
where is the turbo from, whats its mileage, etc?
thanks
VC
n1smo200sx
Comes from Skyline GTR.Stripped and checked,no play on shaft ,still in good condition.Manifold and exhaust side the same as T25 on CA18.Intake and compressor side need some modification.
Phinx
0.7 Bar Boost
Post by Phinx »
Ceramic blade. Its a GTR turbo ...
Basically a T3 compressor with a T25 Flange.
Its allot of work making these fit to our cars
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
63kw - 117nm 1.3- N/A
n1smo200sx
It's the only way to not change the manifold and exhaust and still go over 170kw safely according to some.Spool up also very fast on these turbo's according to experts...Since when is anything easy on a Sx :lol:
widowmaker
Real Name: Walter
Post by widowmaker »
how much work is a lot of work?
what do you mean a lot of work?
do you mean the compressor side. having an intake pipe made to fit, and and outlet, etc.
or do you mean that and the exhaust side modified too?
or is it that, and moving the abs unit, and the wiring harness and the power steering fluid resevoir, etc???
thanks phinc
n1smo200sx
The manifold and exhaust housings is exactly the same.Straight bolt on.
The Oil feed is exactly the same.ALL the need to be done is to make an adaptor for the intake and the outlet.Andre will do it for a few bucks if you dont know how to!!
n1smo200sx
What no takers?There must some smoking underpowered sx's out there?
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
price is bit wacked man... "even" if its a GTR turbo, for the average oke it doesn't mean much, AR rating is also bit low, for high RPM usage.
One will struggle get R1500 for a perfect condition T28 from a S14...
Hairdresser MX5
n1smo200sx
Well.its not a s14 T28,it's a ball bearing turbo.Also the Ca18 doesn't make power after 5500rpm with standard manifold anyways.
havoc 187
Post by havoc 187 »
il offer you R800.00 cash..
Locked
