200sx s13 CA18DET - plugs and filter
JoKeR**
Post by JoKeR** »
i just changed the plugs in my sx from an NGK BKR6EY to a BCPR6ES
which i read up was good for the car. i also just put a cone filter+adapter on.
my car is spluttering a bit but only slightly, it didnt do it before and im hoping it goes away....what could this be from? pls help.
What plug gaps are you running?
@ what boost pressure?
at 0.8-1.0Bar i was always happy with BCPR7es plugs gapped to 0.8 - 0.9mm
JoKeR**
Post by JoKeR** »
my car only running at o.6 bar and it has the BCPR6ES-11 which has a 1.1mm gap, which is standard gap.
JoKeR**
Post by JoKeR** »
i wanna increase my boost but have a std ecu system....
how can i do that, just to like 0.8 bar.
poizen
Real Name: Mical Mackay
Post by poizen »
just do it shal be fine make your plugs 0.8mm gap will work great
JoKeR**
Post by JoKeR** »
must i take my car to a dyno shop or tuner to increase the boost?
and must i buy new plugs now, how do i make the gap 0.8?
im not sure on all this stuff so just need to make sure
The sputtering is because you have now increased your air flow , the car is running lean, I'd suggest 3 things, Walbro fuel pump, plug gap 0.6, reset ECU so that maf can better adapt to new air flow increase.
JoKeR** wrote:must i take my car to a dyno shop or tuner to increase the boost?
If you have a standard T25 turbo, 0.9 is said to be the most relieble boost that turbo can handle, as for going to a dyno, not really nessasary, AFM should be able to adapt after a reset to the new air flow....but a tuner can always set voltage on dyno which would be the best if you can.
No need for new plugs, take them out, use a feuler guage to measure the gap, tap the spark plug bridge slightly against something hard to decrease the gap untill guege is met.
JoKeR**
Post by JoKeR** »
i thought that could be the prob. how much would this cost? and does this mean i need to get new plugs? i just got these ones lol
JoKeR**
Post by JoKeR** »
o ok i see thanx man. its a T28 turbo that i have in now. u think 0.9-1.0 bar will be good? do i take the ecu to a technician to get reset?
Well you don't nessasary need to go for a walbro....but it is the best....you looking anything between R1250-1500 for the fuel pump, you can buy no names that would work, but many people don't trust them, I have never had a isssue though.
The plugs....no need for new ones.
I personally think the t28 will handle 1 bar, many don't, if you can afford it, do the fuel pump and then take it to a good tuner to set up your afm on the dyno to be safe.
JoKeR**
Post by JoKeR** »
sorry for all the q's but i dont have a boost controller or anything so how would i increase the boost.... :oops: im new to the game lol
poizen
Post by poizen »
dude please i know you new to this so we dont want you messing up your car
get a boost controller can get a cheap one for 350 but rather spend the money on a electronic one
take the new plugs you just got get a feeler gauge from auto shop
set the fingets to 0.8 gap then tap the bottom of a plug gently until the feeler gauge can be slid in and out smoothly
or just ask the auto shop you got the plugs to show you how
JoKeR**
Post by JoKeR** »
haha thanx man, i also dont wanna mess up my car...would suck ass.
im gonna have a look for some boost controllers now. so all i need to do is shorten the gap. cool, thanx alot guys.
so its boost controller, reset ecu,plug gap 0.6-0.8mm and fuel pump?
