Wanted: CA18DE ecu
Wanted or for sale
Locked
charlcater
Newbie
Wanted: CA18DE ecu
Post by charlcater »
hi guys,
I own a box shape sentra 1.8 16 valve twin cam with CA18DE engine. It started misfiring on one cylinder recently and the fault was traced to the ECU.
Any idea of where I could track down a replacement one / have it fixed around cape town?
It's reasonably urgent, so any help would be greatly appreciated.
Thanks!
300sx
0.8 Bar Boost
Post by 300sx »
not to be clever or anything, but are you SURE its the ecu? those engines have a well known issue with their ignitors , which often gives the symtom you describe.. ??
reason i ask, i have NEVER heard of the ignition transistors inside the ecu going..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
charlcater
Newbie
yep, unfortunately so. I've had a misfire before, which turned out to be a shot coil, but apparently not in this case.
I hear what you're saying though. It might be worth just getting a second opinion.
300sx
0.8 Bar Boost
Post by 300sx »
yeah i really would get a second opinion, i think it might be worth it..
i dont know if you know how the ca18 ignition system works, but the coils gets fired by the ignitor, which gets trigered by the ecu.. so the ecu is not the part that has a lot of current flowing through it, the ignitor flows the current neccesary to fire the coils.. and its the ignitor that fails 99% of the time.. good luck :wink:
300zx fairlady 1991
charlcater
Newbie
Thanks for the info! Spoke to the mechanic again and the fault actually does lie with the ignitor, as you predicted.
So it seems I'm now looking for an ignitor... :shock:
Locked
