hi guys,
I own a box shape sentra 1.8 16 valve twin cam with CA18DE engine. It started misfiring on one cylinder recently and the fault was traced to the ECU.
Any idea of where I could track down a replacement one / have it fixed around cape town?
It's reasonably urgent, so any help would be greatly appreciated.
Thanks!
Wanted: CA18DE ecu
charlcater
- Newbie
not to be clever or anything, but are you SURE its the ecu? those engines have a well known issue with their ignitors , which often gives the symtom you describe.. ??
reason i ask, i have NEVER heard of the ignition transistors inside the ecu going..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
charlcater
- Newbie
yeah i really would get a second opinion, i think it might be worth it..
i dont know if you know how the ca18 ignition system works, but the coils gets fired by the ignitor, which gets trigered by the ecu.. so the ecu is not the part that has a lot of current flowing through it, the ignitor flows the current neccesary to fire the coils.. and its the ignitor that fails 99% of the time.. good luck
300zx fairlady 1991
charlcater
- Newbie
