High Boosts SX
Highboost wrote:I am quite proud of what it looks like now, just needs to be slammed with
some nice coil-overs.........., and get it running. :roll:
agreed! :D
Highboost
Post by Highboost »
Another day of nothingness !!!! :evil:
Yesterday the motor was completely assembled. Maifolds, turbo's
waterpipes, oil feed, oil return etc etc etc.
Today my tuner is doing a dyno on a stockcar, so my build is on hold.....
So to be continued ...........tomorrow I suppose ... :roll:
Tomorrow night drift practice again at scribante and I will be missing out
once more......... :twisted: :twisted: I'm sick of spectating.....
Highboost
Post by Highboost »
Drift Practice was a blast !!! 8) 8)
Update on my car : Zero
Thursday : Hasn't been touched.
Friday: Tuner promised to have the motor fitted today, so lets see
and?
Who's your tuner?
Highboost
Post by Highboost »
Please don't think I am bad mouthing my tuner( not my intent at all), I'm just giving the updates as they happen. He's got a shop and my car is not
the only one there.
It's PPR - used to be in george but now moved to PE.
Got to the shop yesterday after work and the motor is hooked up to the
BLock and Tackle and the car is parked behind the motor, ready to be
fitted, but not in yet.
Will keep you guys up to date!
Highboost
Post by Highboost »
Have just been to the shop, they worked on the car saturday, motor is in and in place mountings just needs to be fastened.
But so far no-one at the shop today. :roll: So don't know what the plan is
for tday.
The plan is.....
THERE IS NO PLAN :wink:
at least the engines fitted :twisted:
Highboost
Post by Highboost »
Update: Motor fitted!!!! engin and gearbox mounts fastened. old MR Turbo
Management removed as well as all previous wiring.
Engin mounts were old and broke when fitted so in went a new set of
engin mounts, now the motor is sitting quite high in the front, and to my
untrained eye it looks like the bonnet is not gonna clear the motor.
The sump clears the motor with milimeters to spare, And there's a gap of
about 1.5cm between the motor and the firewall. Does this sound normal?
Highboost wrote:Update: Motor fitted!!!! engin and gearbox mounts fastened. old MR Turbo
Yes sounds about right. might have to lower the motor some more but then the sump wont clear
RB25SX
Post by RB25SX »
rat wrote:Yes sounds about right. might have to lower the motor some more but then the sump wont clear
Should not be a problem, but if u need another 10mm, u can space the crossmember down by 10mm. I had to do that to fit higher RB30 under S14 bonnet.
R32 GTR
Highboost
Post by Highboost »
Visited the shop last night after work and at about 13.00 tday, No progress since last time. :?
The car is under about 2meters of dust already - :lol: :lol: :lol:
Will return to the shop again after work to see if there were any progress
after 13.00....
Highboost
Post by Highboost »
Could not manage to go around last night, but just come from there and
no-one home. All the doors closed, no-one there.
Suppose he'll be in later. :?
he had to go buy grociries....and eat some ice-cream...do the hair and the nails....buy some underware.....you know....normal things when you not lis for work.
RudeBoy
Post by RudeBoy »
these things dont happen overnight - I wont work on anyones car if they going to come check up on me every day or even twice a day
can only lead to one of two things - your "tuner" tells you to f*ck off or he rushes the job just to get rid of you
differant story i suppose if yours is the only car there or you paying him enough to just focus on your car
just my 2c
Very true rudeboy....but also in all fairness....not nessasarily about this topic.....if a tuner tells you a month.....then you kinda expect that....
