Please don't think I am bad mouthing my tuner( not my intent at all), I'm just giving the updates as they happen. He's got a shop and my car is not
the only one there.
It's PPR - used to be in george but now moved to PE.
Got to the shop yesterday after work and the motor is hooked up to the
BLock and Tackle and the car is parked behind the motor, ready to be
fitted, but not in yet.
Update: Motor fitted!!!! engin and gearbox mounts fastened. old MR Turbo
Management removed as well as all previous wiring.
Engin mounts were old and broke when fitted so in went a new set of
engin mounts, now the motor is sitting quite high in the front, and to my
untrained eye it looks like the bonnet is not gonna clear the motor.
The sump clears the motor with milimeters to spare, And there's a gap of
about 1.5cm between the motor and the firewall. Does this sound normal?
Highboost wrote:Update: Motor fitted!!!! engin and gearbox mounts fastened. old MR Turbo
Yes sounds about right. might have to lower the motor some more but then the sump wont clear
he had to go buy grociries....and eat some ice-cream...do the hair and the nails....buy some underware.....you know....normal things when you not lis for work.
